Halo headlight problems
Old Jan 24, 2012 | 11:04 AM
tnvols123's Avatar
tnvols123
Default Halo headlight problems
My projector headlights work great but the only problem I am having is they do not sit flush where they should mount. there is a pin that does not go in the hole, but even if it did there is nothing to hold it there. I have taken them out and put them back in so many times trying to fix the problem, but now its getting to the point the plastic housing is starting to fall apart. Anyone else had this issue? If so will you explain in detail on how to fix the problem? Thanks in advance.IMAG00471.jpgIMAG00481.jpg
Old Jan 24, 2012 | 11:08 AM
thunder98110's Avatar
thunder98110
none of the single lens (blinker molded into 1 unit) always have fitment issues.
Old Jan 24, 2012 | 11:13 AM
NickCornell's Avatar
NickCornell
Looks like a transformer thumbs up
Old Jan 24, 2012 | 11:34 AM
dodgeramguy85's Avatar
dodgeramguy85
In that hole there is supposed to be a plastic bushing and then your head light is held in by the bushing. Mine was tight so it sucked my light in just where my factory light was. They say the one piece lights dont fit as well but my fit really well.
Old Jan 24, 2012 | 12:44 PM
tnvols123's Avatar
tnvols123
Yeah that would be my problem then, because I do not have a rubber bushing. Thank you for the help
Old Jan 24, 2012 | 01:00 PM
Brian_'s Avatar
Brian_
like dodge ram said he had better luck then me because mine are nowhere ner that flush a good 1/4 gap is present in mine
Old Jan 24, 2012 | 01:08 PM
dodgeramguy85
Its plastic bushing but if your handy you could come up with a piece of rubber. It would prob work the same.
You can get a piece of weather stripping and put around it to close up the gap some.
Old Jan 25, 2012 | 08:52 AM
tnvols123's Avatar
tnvols123
Well I found the perfect bushing in my stash only to find out that the plastic housing of the headlight will only allow it to go back so far, which prohibits the pin from being able to enter the hole. Oh well its not a major deal, I would just like the headlight to have that little extra support.
Old Jan 25, 2012 | 01:10 PM
Brian_'s Avatar
Brian_
yeah that would probably work. it still makes me mad those guys sent me the wrong headlights off ebay, i should have had the tinted ones like yours. mine still look pretty good though for the clears imo.
Old Jan 25, 2012 | 02:37 PM
crateampsrock's Avatar
crateampsrock
I bought the same exact headlights. My tabs barely fit, and I had to modify the clips with the bolts and add several washers to make it fit right... good luck
