powersteering reservoir problem
Old Jan 24, 2012 | 04:31 PM
lodz08's Avatar
lodz08
Default powersteering reservoir problem
hi has anyone had a problem with the pump/reservoir connection? i have in the past month put in 2 pumps and today just changed my rack with new lines. I went to bleed the system out which looked like it worked i had no noise whats so ever until i took it for a quick test around the block to which it started whining again, me already being fed up checked all the lines they were all secure it wasnt till i saw that the connection between the pump and reservoir was leaking. i have looked online everywhere to buy a new reservoir and from what i see you can only buy used from the junkyard or can someone tell me the best way to seal that connection.
Thanks Chris!
Old Jan 24, 2012 | 06:47 PM
alt-fuel's Avatar
alt-fuel
Now is it the pressure side or the return? I replaced the pump on mine and used my reservoir which has a large O-ring and other o-rings for the smaller fittings.
Old Jan 24, 2012 | 09:30 PM
Dakmm's Avatar
Dakmm
I've been battling a p/s whine for a couple months myself lodz08. Cannot get it to go away. 2 pumps, 6 quarts of fluid and every friggin bleeding technique there is....nothing.
So I guess my next course of action needs to be replacing the rack and lines?? I didn't have any issue with my reservoir leaking after installing either pump, I just used the new o-rings that came with it. My only reservoir issue is that the metal screen in it is ripped, so I'm thinking about getting a new one myself.
pretty sure I've read before that the easiest way to get one is the junkyard, I think most places only sell them with the pump, not by themselves. Let me know if you find a place that sells them alone. I will try a new reservoir before I rip out the rack and lines.
I can barely stand to drive the truck with this damn whining. What is the deal with these POS Dodge p/s systems anyway??
Old Jan 25, 2012 | 08:19 PM
lodz08's Avatar
lodz08
no its leaking from the reservoir where the nipple goes into the pump i believe its that plastic seat is bad on it i don't know where to buy it i'm considering buying a new pump with a reservoir on it. and DAKMM i feel your pain i haven't found a place that sells it but on rockauto they sell a acdelco with the reservoir for 95 bucks, if i cant fix that seal problem i will end up buying that one. also my rack was bad after i installed the second pump, it blew the seal in the rack i spent about 6 frustrating hours replacing it.
