poor air blowin from defrost
Old Jan 31, 2012 | 01:32 AM
garciajuanelo's Avatar
garciajuanelo
Smile poor air blowin from defrost
Hello everybody and thanks for reading about my problem.
it blows good cold and hot air i just replaced the resistor but de only problem is that when you set it to defrost most of the air is going on the floor and very little goes on the defroster, I thought it was the AC/ heater control so tried a new one and it does the same thing.
has any of you have this problems before, or do you have any suggestions what I should check for?
THANKS FOR YOUR HELP
Old Jan 31, 2012 | 06:34 PM
UWAdventurer's Avatar
UWAdventurer
Sounds like the diverter door is not functioning properly. Have you checked the search function? or google the problem. I know I have read something on this, I just can't remember where. Sorry, I hope this helps some.
Old Jan 31, 2012 | 06:51 PM
98DAKAZ's Avatar
98DAKAZ
Talking try this ! !
try this ! !
With car running flip the vent control back and forth fast a few times works for me kind of frees the flapper up.
Car must be running these things use vacum for them to work.
Works some times
