Best/Cheapest way to lift?
Old Feb 4, 2012 | 01:50 AM
aircruiser's Avatar
aircruiser
Default Best/Cheapest way to lift?
I am sure this question has been asked before but a search didn't turn up much. I just got my truck and want it to sit a little higher. I am not looking to do anything to soon but down the road, I would like to do 2-3" of lift but no body lift. I've done the torsion bar crank on a few of my buddies Chevys but does it work well on dakotas? Can it be perfectly re-alligned after? As for the rear, would and add-a-leaf be better or blocks? I plan to tow with this truck down the road (~5,000lbs) so I don't want any problems with axle wrap or anything. My plan is to run 265/75/16 Duratracs, but 285s look mean!
Again I just want it for looks mainly as this truck sees mainly road but some wooded trails up north that requires 4lo which is why I am getting an agressive tire.
Thanks in advance!
Old Feb 6, 2012 | 11:32 AM
aircruiser's Avatar
aircruiser
Anybody?
Old Feb 6, 2012 | 11:40 AM
Trent479's Avatar
Trent479
T bars will work if you have 4wd! And yes you can get it alligned right! Add a leaf would be the best way to go if your towing! Blocks will do the job as well though. U can get about 2 inches from the t bars! Thise tires are gonne look good man
Old Feb 6, 2012 | 11:42 AM
aircruiser's Avatar
aircruiser
Thanks man so I can do it just like a chevy and do about 2 1/2 turns on the bolt? And any recomendations on add-a-leafs that wont sag? And yup my truck is 4WD!
