I'm back!!!...Finally
Old Feb 7, 2012 | 03:21 PM
00daksport25's Avatar
00daksport25
Default I'm back!!!...Finally
Hey all, I know it's been awhile since I've been on, been busy. I've also been busy working on my truck. Some of you already know that I have a 2000 Dak Sport w/ the 2.5, but I can assure you it is not the same truck it was a few months ago. Below are just some of the things that I've done to it and plan on doing to it. Let me know what you guys think. Thanks!
Suspension: Front and Rear Belltech sway bars, Belltech links, Energy control arm bushings, XRF ball joints, Moog coil springs, Moog inner/outer tierod, KYB Monomax front shocks, Monroe SensaTrac Load Adjusting back shocks, Energy leaf spring bushings
Motor: Rebuilt at 233k, bored .030 over, port and polished head, 4.0 TB, 4.0 TB spacer, homebrew ram intake w/ custom heat shield, 180* stat, A/C delete
Future Projects: EBC 3GD Sport Rotors, EBC Yellowstuff 4000 Kevlar pads, drum to disc conversion, full exhaust, Posi rear end
Old Feb 7, 2012 | 03:27 PM
98DAKAZ's Avatar
98DAKAZ
Default so hows the 2.5
so hows the 2.5 I have that engine also so few do its always good to see someone with the 2.5 and what they do to thier engines.
Old Feb 7, 2012 | 03:33 PM
00daksport25
Hey 98DAKAZ, how you been? did you ever get around to rebuilding your cylinder head?
Old Feb 7, 2012 | 03:37 PM
98DAKAZ's Avatar
98DAKAZ
Default I got lucky
I got lucky I decided to recheck my presser and the second time they were just fine so no need.
The gage I think had a bad seal the second one was a good gage.
They were rentals from autozone and those things get bashed around.
Old Feb 7, 2012 | 03:54 PM
00daksport25
Ah well that's good news. Yeah rentals from Autozone are pretty much a toss up if you get a good one or not. have you done a leak down test? that is what prompted me to rebuild my motor, i was leaking about 67%, mostly through my rings.
Old Feb 7, 2012 | 04:08 PM
chris1996's Avatar
chris1996
thats sound nice and... good luck....!!!!
