Car Stereo Install Help!
Old Feb 25, 2012 | 10:13 PM
dlopez916's Avatar
dlopez916
Default Car Stereo Install Help!
I have searched and searched for a wiring diagram, but none match my 97 Dakota. I am getting NO Power to the stereo. I have the pink wire (which seems to be different) and the blue and white, blue and red wires. These dont match any diagrams I find online. Has anyone dealt with this, and what's the fix! Thanks!
Old Feb 25, 2012 | 11:20 PM
01SilverCC's Avatar
01SilverCC
Welcome to the forum. This should be the factory wiring info for your truck.
Constant 12 volts positive: Red or Pink
Accessory 12 volts positive: Red/White
Illumination: Black/Yellow
Dash light dimmer: Orange
Speakers:
Left Front (+) Green
Left Front (-) Brown/Red
Right Front (+) Purple
Right Front (-) Dark Blue/Red
Left Rear (+) Brown/Yellow
Left Rear (-) Brown/Blue
Right Rear (+) Dark Blue/White
Right Rear (-) Dark Blue/Orange
Check with a test light or volt meter to be sure you have power on your constant and accessory 12 volt wires. If you have power on both wires but the radio still will not turn on, you may have a bad ground. If you used the factory silver braided ground strap for your ground, cut it loose and run a new ground wire from the ground wire of the new radio down to one of the kick panels. Ground the wire in the kick panel to clean bare metal under one of the factory-installed nuts or bolts there. The factory radio ground straps are notorious for corrosion and contamination and do not make good grounds at all.
If you have no power on the constant 12 volts wire, you probably have a blown fuse. Check the fuses in both the interior fuse panel on the side of the dash and the fuses in the Power Distribution Center under the hood, next to the battery. It may or may not be listed in the owner's manual but look for a fuse that is labeled radio memory, clock, maybe cig lighter, or check the I.O.D. Ignition Off Draw fuse, if you have one. If all elese fails, be sure the ignition is off and pull each fuse out one by one until you find the blown fuse.
I hope that helps.
Jimmy
Old Feb 25, 2012 | 11:43 PM
ibcnul8r's Avatar
ibcnul8r
One of the easiest things I have found for wiring a new or different stereo other than factory, is to go to Car Toys and tell them you need the wiring harness for your year make and model. Wire it to your stereo and then just plug it in to your factory plug. I've done it this way on several of my vehicles over the years.
Old Feb 26, 2012 | 03:01 AM
dlopez916's Avatar
dlopez916
Jimmy-
You are DA MAN! Thanks for the tip on the IOC Fuse, fixed me right up! I appreciate it!
Old Feb 26, 2012 | 01:28 PM
01SilverCC's Avatar
01SilverCC
YW. Glad to know it was an easy fix.
Jimmy
