How to take off seat belt
Old Feb 26, 2012 | 03:26 PM
DodgeDNick's Avatar
DodgeDNick
Default How to take off seat belt
I have a 2001 dodge Dakota club cab and I'm replacing the speakers myself but I have no idea how to take off the seat belt connected to the trim
Old Feb 26, 2012 | 06:26 PM
01SilverCC's Avatar
01SilverCC
Push up on the plastic cover over the seat belt anchor and remove it. Then use a T50 torx socket to remove the anchor bolt.
Jimmy
Old Feb 26, 2012 | 09:24 PM
moe7404's Avatar
moe7404
in some states just any one is NOT allowed to remove, or install, seat belts, you have to be approved by the state. i would not even think about it unless i have a factory service manual. they could have things going on you dont know about. i wouldnt TOUCH it. "not my job"
Old Feb 27, 2012 | 09:49 AM
McNasy's Avatar
McNasy
its just 1 bolt. he isnt replacing the airbag system. remove the bolt, remove panel, remove speaker, replace speaker, panel and reinstall seatbelt bolt. done.
Old Feb 27, 2012 | 01:05 PM
jondakotaguy's Avatar
jondakotaguy
Yup.. I just did this yesterday matter of fact.. it's really simple if you have the right tool to remove the bolt..
Old Feb 27, 2012 | 05:38 PM
dodgeramguy85's Avatar
dodgeramguy85
Your also not supposed to remove your the exhaust pipe after the cat either but people do it including me lol. Small screw driver to pry up the small plastic part at the top then torx to remove it.
Old Feb 28, 2012 | 10:16 AM
DodgeDNick's Avatar
DodgeDNick
The bolt is to tight. Can anybody give me an exact way of doing this
Old Feb 28, 2012 | 01:52 PM
01SilverCC's Avatar
01SilverCC
Seat belt bolts can be pretty tight to remove, especially if they have never been removed before. Maybe whack the bolt head a few times with a medium sized hammer, or if that does not work maybe you could have someone hit it a few times with a Torx socket on an impact wrench.
Jimmy
Old Feb 28, 2012 | 07:08 PM
dodgeramguy85
1/2 ratchet had no problem getting mine loose just had to put some force behind it. Hit the ratchet with a hammer a few times
Old Feb 28, 2012 | 09:25 PM
eagle7's Avatar
eagle7
Yeah, you need a ratchet and a socket type of torx wrench.
