Need to know how to change an oil pump
Old Mar 19, 2012 | 10:21 PM
Patricia Rowbotham's Avatar
Patricia Rowbotham
Default Need to know how to change an oil pump
Could someone please tell me how to change the oil pump on a 3.9L 4x4 2002 dodge dakota sxt? And how long it might take.. I know I need new oil, the oil pan gasket, and the oil pump.
Old Mar 19, 2012 | 11:50 PM
moe7404's Avatar
moe7404
i dont much about changing the pump, but DO put grease in the pump so it pulls oil at start up.
Old Mar 20, 2012 | 11:03 AM
crateampsrock's Avatar
crateampsrock
labor book time is 5.4 hours.
raise vehicle, drain oil, remove dipstick, remove exhaust assembly, remove left engine to transmission strut, loosen right side engine support bracket cushion through bolt-nut and raise engine slightly, remove oil pan by sliding it backward and out, remove one peice gasket (which they say is re-usable...goodluck with that)...then remove oil pump from rear main bearing cap.
Good luck to you. Be glad you dont have the 4.7, I just rebuilt my motor, and to replace the oil pump on that you have to remove all the timing chains and sprockets, which includes removing valve cover gaskets and removing the sprockets off the cams...
and moe is 100% correct. When you do get the new pump ready to put in, pack it full of either engine assembly lube (my preference) or ive seen some people that use vasoline cause it will disolve into motor oil. You'll pull the plugs out of the motor and turn it over until you get oil pressure. Replace plugs and start...
Old Mar 20, 2012 | 01:10 PM
98DAKAZ's Avatar
98DAKAZ
Default what cost from a shop $650?
Thats a shocker.
Why is a new pump needed?
Are you sure its bad?
Old Mar 20, 2012 | 02:16 PM
5hundo's Avatar
5hundo
Thats a shocker.
+1
Considering what they do, those parts wear out very slowly. Unless your oil became contaminated and prematurely wore out the pump, I am skeptical that this is the problem. Even with oil contamination you'd expect the bearings and/or rings to "shell out" first.
Old Mar 20, 2012 | 04:43 PM
crateampsrock
Im sure a shop would charge more. They have mark-up on the pump itself, plus a slight markup on labor. Also they will probably want to go ahead and replace the oil pan gasket. Id say a safe shop est. would be closer to around $800
