Dodge Dakota 2000 bucking
Old Aug 11, 2005 | 11:44 PM
nt_op_sys's Avatar
nt_op_sys
Default Dodge Dakota 2000 bucking
My first time here. I have a Dodge Dakota 2000 V6 3.9. When it warms up it will start bucking when I give it gas. I noticed it does it at the lower RPMS (under 2000). When I'm 3rd, 4th or 5th gear and go up a slight incline is when I notice it the most. It seems to get worse every day. I have changed spark plug wires, rotor, dist. cap and plugs. Still the bucking continues to get worse. I had them check the computer for codes and it said plug wire 5 was bad, so we replaced all the wires. No codes since we replaced the wires. The odd thing is it runs fine when the engine is still cold.
Old Aug 12, 2005 | 09:03 AM
RP Racing940's Avatar
RP Racing940
Default RE: Dodge Dakota 2000 bucking
10 to 1 its teh crankshaft position sensor. Mine did exactly what yours is doing and thats what fixed it. It would surge and buck like mad for 5 min then clear out. Then it got worse and worse. Would barely get over 45 when it did that.
