Door Hinge pin and bushing
Old Mar 23, 2012 | 12:59 AM
moparman_2004's Avatar
moparman_2004
Default Door Hinge pin and bushing
who has replaced there door pin bushings on the dakota yesterday i noticed that mine had some play and the bushing has started to fall apart is there any tricks normally there simple and were did you get them at thanks
Old Mar 23, 2012 | 07:41 PM
dolittle's Avatar
dolittle
Try NAPA they had some for my Chevy truck a few years back.
Old Mar 24, 2012 | 10:25 AM
huseman808's Avatar
huseman808
Ive done it. You can buy a kit at oreillys or advance auto. I think the brand is "HELP!" they will say they will only fit for up to like a 98 or 99, but they will work on yours. You just have to cut the old ones out with a grinder.
Old Mar 24, 2012 | 07:53 PM
JBs DAK's Avatar
JBs DAK
Yep, the HELP section at Advance has 'em. I did them 3 weeks ago.
I used a air-chisel-gun to knock the old ones out.
You need two people to do it unless you have a good way to hold
the door steady once the 1st. bolt comes out.
Old Mar 24, 2012 | 08:00 PM
moe7404's Avatar
moe7404
i saw a guy in tv, he showed to get some thin plates, metal of plastic, to put in the spring to un load the spring to get it out, with the hood was just half open. he only showing how to get the spring out.
Old Mar 27, 2012 | 01:33 AM
moparman_2004
Ok thanks I was lost I had a hard time finding them for the later years and I didn't think they changed the hinges but thanks
