Window regulator compatablity
Old Mar 31, 2012 | 12:12 AM
emesnarf's Avatar
emesnarf
Default Window regulator compatablity
I have a 2000 Dakota Quad Cab with manual crank windows. The front passenger side regulator is broken, I was wondering what would fit to replace it?
I would assume the extended cab trucks would have longer doors so would have bigger glass than the quad cab and regular cab trucks. Would a regulator from a durango fit? Assumeing the parts stay the same across the two lines.
There are many wreckers in the area so I can likeley find one, I just would like to have an idea what exactly I am looking for before haveing two trucks apart and haveing the wrong part to toss in.
Thank you for your input
Old Mar 31, 2012 | 10:18 AM
00DakDan's Avatar
00DakDan
Section Moderator
You won't be able to use the regulator off of a regular or club cab.
It's not the door size. Your regulator should use cables to raise/lower the window. The regular/club cab use a scissor style regulator - not compatible.
Old Mar 31, 2012 | 08:38 PM
emesnarf's Avatar
emesnarf
Thanks for the info, any ideas if the Durango regulator would work? You are correct on the cable set up being used in the quad cab. Sounds like I have to search for another base quad cab.
Old Mar 31, 2012 | 08:44 PM
00DakDan's Avatar
00DakDan
Section Moderator
I'm not sure on a Durango. I think they're cable operated but whether they'll fit or not, no clue.
good luck.
