Tickin' Noise
Old Apr 17, 2012 | 02:17 PM
Futbolplayer's Avatar
Futbolplayer
Sorry for the late reply...the tickin' noise is there when the engine is warm and/or cold...it stays pretty consistent...I might have to get a stethoscope to see exactly where it is coming from...I am thinking that it might be a lifter that has started to stick a little bit over time...
I am curious if I ran seafoam through the crankcase and intake, would it help?!?
Thanks for the help!!!
Old Apr 18, 2012 | 03:56 PM
5hundo's Avatar
5hundo
I tried a qt of Rislone in the crankcase and it hasn't helped. I think all of those additives are intended to do the same thing.
A friend of mine has a mechanic that suggested running a heavier weight of motor oil, like 20W-50. Anyone ever try that?
Old Apr 18, 2012 | 04:20 PM
tssiTanker's Avatar
tssiTanker
Just saying, but on this old chevy I used to have an exhaust manifold leak on, it didn't matter if it was hot or cold the ticking was still there. I ran every engine additive through it I could buy before I figured out it was an exhaust manifold leak. Tightened the bolts up and the noise was gone.
Also if you have an old piece of rubber hose laying around, you could use that instead of buying a stethoscope. Works just a well.
Old Apr 18, 2012 | 05:24 PM
5hundo's Avatar
5hundo
That's most likely the rear-most bolt on the driver's side exhaust manifold. I've sheard that thing a couple times in my 175K...
Old Apr 29, 2012 | 11:09 PM
gassmann66's Avatar
gassmann66
got the same problem but on the passenger side, really noticable on start up but practically goes away after warmed up unless your right by the passenger fender, the bolts are just so friggen hard to get at
