Tranny quit working then worked today
Old Apr 23, 2012 | 11:55 AM
jbhodj's Avatar
jbhodj
Default Tranny quit working then worked today
1995 Dodge Dakota 5.2L 4x4 with 160K
Tranny didnt want to go into reverse, made a whirring sound when I tried. Went into drive and seemed to shift in OD fine until later when it stopped working altogether. No forward or reverse and going into park had a sound like it was not fully going into park.
Truck was towed home, sat in drive all day and then today when I was letting someone else listed to the sound I heard, the truck went into forward, reverse and park with no slippage, sounds or issue.
Didnt have any signs or fluids leaking. Tranny fluid is red, smells fine I guess. No fluids leaking. Sounds I heard were not clunking or grinding, more like gears not engaging fully I guess.
Worse case I thought was tranny was bad at first until I started it up today and it seems to be back to normal.
Thoughts on what I maybe dealing with would be appreciated.
Thanks
Old Apr 24, 2012 | 09:20 AM
Vladek's Avatar
Vladek
sounds like you need a rebuild or swap the tranny. but i don't have much exp. with transmission work. i usually take it to the shop for that.
