Help with turn signals
Old May 7, 2012 | 01:43 PM
earthur33's Avatar
earthur33
Default Help with turn signals
all turn signals and Hazards are gone! Soo what I've done so far with no solving is... replaced the module under the dash and checked the fuses under the hood and the fuse box near the drivers side door... Any other idea's?
Old May 8, 2012 | 08:49 PM
moe7404's Avatar
moe7404
iam not sure but i think the power might go through the ignition switch. dumb me i need to look at my service manual. ill take a look and get back to you. find the junction block, run-acc-a31, check the fuse 19 10a . and power distribution center, batt A0 fuse 1 30A. there is lots more but to much to run down now. i dont know where those things are.
Old May 9, 2012 | 10:25 AM
earthur33's Avatar
earthur33
Ok I'll check those things....More info. the turn signal module makes one "click" when the stick is moved either for left or right turn (up or down)however, there are no lights on the dash board nor do the turns signal lights flash at all
Old May 9, 2012 | 10:28 AM
earthur33's Avatar
earthur33
Also, I don't know of any other function that is not working as it should
Old May 9, 2012 | 10:30 AM
earthur33's Avatar
earthur33
thx Moe!
