reverse lights
Old May 17, 2012 | 05:23 PM
merryweather's Avatar
merryweather
Default reverse lights
I'm kinda new to the Dakota world. I'm not even sure what a 2nd generation Dakota is. If I had to guess I would say that's what I have. I've got a 98 Dakota with the 318, paint,rims,bags.... Blah,blah,blah.... My reverse lights are not working. It's not electrical! Could it be the linkage inside the tranny? HELP!!!
Old Jul 13, 2012 | 03:59 PM
Tom A's Avatar
Tom A
Section Moderator
How do you know it's not electrical? What have you tested already?
Old Jul 15, 2012 | 02:18 PM
merryweather
My cousin is a wiz with electrical things. Its good all the way down to the switch itself that screws into the tranny.
Old Jul 15, 2012 | 08:39 PM
Tom A's Avatar
Tom A
Section Moderator
So, you have power going to the switch but not coming out of it? Kinda sounds like a bad switch.
Old Sep 18, 2012 | 04:35 PM
merryweather
Yeah, it does sound like that but its not.
Old Sep 18, 2012 | 06:56 PM
00DakDan's Avatar
00DakDan
Section Moderator
Put a jumper across the terminals at the switch. See if the lights work then.
Old Sep 19, 2012 | 06:46 AM
merryweather
I have power to the plug. What would that help? Do you know anything about how the linkage works with the switch or not?
Old Sep 19, 2012 | 09:44 AM
jondakotaguy's Avatar
jondakotaguy
Did you ever think to check the connections there, i assume your break lights work? Have you checked and swapped the bulbs? to make sure the bulbs aren't blown?
Old Sep 19, 2012 | 10:38 AM
00DakDan's Avatar
00DakDan
Section Moderator
It'd help because you're not giving us much to go on.
Jump the switch and see if the lights work. If they do, great, we can rule out everything but the switch and linkage. Then, take the switch out of the transmission, you might leak a bit of fluid but not much. You'll be able to feel/see the detents in the linkage assembly. In park/neutral (all on the one switch) the fingers should be centered in the opening.
If it lines up replace the switch.
Old Sep 20, 2012 | 05:00 PM
merryweather
I have changed the bulbs and the switch. I have chased the electric to the switch. I checked both switches and they are good.
