loss of power
Old May 25, 2012 | 11:51 AM
nickdakota1999's Avatar
nickdakota1999
Question loss of power
99 3.9L Automatic Dakota. Issue- after start up the truck goes couple blocks and then starts to idle bad and lose power for about 30 seconds and then goes away and runs perfect. i had exhaust leak that i thought was causing but had it fixed. Also changed PLUGS,WIRES,CAP,ROTOR,PCV and has a new K&N air filter on it. Took it to Advance Auto and only code coming up was O2 sensor bank 1 high voltage. any help would be greatly appreciated
Old May 25, 2012 | 05:50 PM
sxrsil3nt's Avatar
sxrsil3nt
Does it backfire or make a popping noise when it does it? If so mine does the same thing and I thought I fixed it by replacing the crank sensor - it ran fine for a week and then it did it again.
Old May 25, 2012 | 05:52 PM
slims's Avatar
slims
Sub'd
Old May 26, 2012 | 11:03 AM
nickdakota1999
i bought a new 02 sensor. but before putting in i just unplugged my old one that was sending the bad code(pre-cat) and the truck ran fine. so turns out when it was cold that bad signal from o2 would cause the hesitation and backfire.
