AX15 Transmission
Old Jun 7, 2012 | 04:35 PM
98DAKAZ's Avatar
98DAKAZ
Talking Where is 99
00DakDan Where is 99?
Old Jun 7, 2012 | 05:32 PM
Brian_'s Avatar
Brian_
any rough estimates of what this will cost?
Old Jun 7, 2012 | 06:20 PM
00DakDan's Avatar
00DakDan
Section Moderator
It varies too much across the country. I expect you can find someone cheaper there than I can in MA. It also depends on exactly what it needs. It's not usually the parts that are that bad, it's all the labor.
If you want, you could get one out of a boneyard and put it in. Some places will guarantee the parts. Keep your old one so if you decide to rebuild it later you an.
Check out www.car-part.com. I know you have lots of u-pull places in PA, my folks are in Centre county.
Good luck.
98, I guess you found 99. Just don't start with the "Cone of Silence" thing.
Old Jun 7, 2012 | 06:41 PM
Brian_'s Avatar
Brian_
oh yeah plenty of places i was over at one the other day getting new emblems and a ac switch.
its unfortunite because this is the truck that i learned how to drive manual on. my 5th gear is pretty noisy would that be due to a throwout bearing?
Old Jun 7, 2012 | 07:44 PM
00DakDan's Avatar
00DakDan
Section Moderator
It's not likely a noisy 5th would be due to the throwout bearing. It wouldn't really matter the gear you were in.
Usually a noisy throwout bearing is most obvious when you press the clutch pedal. In my Dak I had one that sounded like a squealing pig no matter what the pedal position. I could play a tune on the thing until it grenaded, literally, and all the ball bearings fell out.
You may have some bearings that need replacing too. Give the boneyards a check, it's worth a shot.
Old Jun 7, 2012 | 08:46 PM
98DAKAZ's Avatar
98DAKAZ
Default Ha Ha thats good
Missed by that much!
Old Jun 8, 2012 | 10:35 AM
Brian_'s Avatar
Brian_
i have no insight on transmissions, they are like a new language
Old Jun 8, 2012 | 10:52 AM
98DAKAZ's Avatar
98DAKAZ
Default ok
Start by getting some prices from a few shops what they offer you. Don’t forget the new clutch in the price.
Just tell them what is wrong with it have them drive it and explain the problem to them.
On carpart.com see what’s available to you locally. http://www.car-part.com/
call any local 4x4 or Dakota clubs ask for any recommendations regarding your truck and a good trans shop to go to for your AX 15, Jeep clubs are good they use the AX 15 in older Jeeps also.
Old Jun 13, 2012 | 05:57 PM
Brian_'s Avatar
Brian_
transmission shop by me wants $1200-2000, like what the ***?!
Old Jun 13, 2012 | 07:58 PM
00DakDan's Avatar
00DakDan
Section Moderator
Check the boneyards. http://www.car-part.com
It's the labor they get you on.
