got codes
Old Jun 17, 2012 | 04:23 AM
NintendoKD's Avatar
NintendoKD
Default got codes
borrowing a truck from a friend, he has the following codes.
P0505
P0132
p1899
pend: P0135
I cleared them and the o2 one came right back on.
about the truck, this has made a couple of trips back and forth from NorthCarolina to Cali. and vice-versa. has an upgraded ignition coil from MSD, headers, a TB spacer, I JUST changed the oil, tranny fluid is good, and has been recently changed with the filter. there was a tune put on it according to my buddy, but I am not sure what. the cats have been removed, and flowmasters put in place. It spurtters when decel. and backfires from time to time, also while decel. sounds like it has a cam, but he insists that there is no cam. I know there is a vacuum leak, and want to try and fix her up a bit before I give her back, the friend is an old retired Marine, and I always return in better cond. if I can. I would just love to swap out for some good aftermarket heads and a supercharger to surprise him, but even my kindness has it's limits "and my wallet"
Old Jun 17, 2012 | 04:25 AM
NintendoKD's Avatar
NintendoKD
I tossed some acetone in the tank, as well as some into the vacuum system, via the hose from the booster, seemed to help some of the issues, she seems a bit happier now.
Old Jun 17, 2012 | 12:09 PM
NintendoKD's Avatar
NintendoKD
98 dakota, with just shy of 200k. I just cleaned the battery terminals, needs new cables, the corrosion was pretty bad. exhaust leak on the pass side on the collector, leak on the drivers side at the cyl. head, needs a new set of exhaust gaskets.
