Oil pressure?
Old Jun 18, 2012 | 07:33 AM
UWAdventurer's Avatar
UWAdventurer
Default Oil pressure?
My '97 5.2L is ony showing about 20-25 pounds of oil pressure, just above the first hash mark, but not close the the 40 psi mark. I am running 5W-30 synthetic oil. Seems low and does not appear to change with rpms. Bad sending unit? Where is the sending unit on this engine.
Thanks all.
Old Jun 18, 2012 | 09:08 AM
jondakotaguy's Avatar
jondakotaguy
By the dist. on the back side of the motor.
Old Jun 18, 2012 | 03:14 PM
User's Avatar
User
I would do a manual test first before changing the sensor.
Could be bad bearings or oil pump, but anything above 10psi should be ok for the 5.2 and 5.9 motors.
Old Jun 18, 2012 | 05:14 PM
jondakotaguy
I know mine is the sensor.. slightest rise in temps seems to make the sensor MIA. Oil Pressure is good on Mech gauge. Seems common problem i'm always reading about..
Old Jun 30, 2012 | 07:29 PM
UWAdventurer
Thanks all.
