Steering Play & Ticking Noise = Bad Steering Shaft?
Old Jun 18, 2012 | 07:49 PM
priceman14's Avatar
priceman14
Default Steering Play & Ticking Noise = Bad Steering Shaft?
My 2wd v6 Dakota has some play in the steering - about an inch to the left and right from center. If I move the wheel back and forth repeatedly, I can usually hear a ticking noise as well.
We already had the driver's side wheel fender liner out to do another repair, and we noticed the u-joint on the steering shaft has some corrosion on it, though we couldn't determine 100% that it's the cause of the play, and in my opinion, the ticking noise seems to be coming from higher up in the steering shaft.
Is a bad steering shaft a common cause for play on Dakotas? How hard is it to replace?
I did find some posts on forums about steering shafts causing play, but in all of the accounts I saw, people with failed steering shafts were having a lot more play than I do.
Thanks in advance for replies.
PS. We know ball joints aren't the issue, 3 out of the 4 on my truck were replaced with greasable Moog ball joints.
Old Jun 18, 2012 | 09:41 PM
mmguy18's Avatar
mmguy18
Steering shaft are a issue. Not hard to change. Can be a little hard to get off of steering rack.I remove the bolt and there is a split there took a dull chisel and open it up to get it off. Shaft can be expensive got mine off of E-Bay at a Dodge dealer (Steve White Motors of N.C.) for $200 and is consider cheap.
Old Jun 20, 2012 | 03:01 PM
priceman14's Avatar
priceman14
Thanks.
Old Jun 20, 2012 | 03:25 PM
rottenkid's Avatar
rottenkid
Got mine for $96 on Amazon.
Usually if it's the shaft, the steering has a loose-tight-loose feeling. Since the U-joints wear out.
Old Jun 20, 2012 | 10:00 PM
Brian_'s Avatar
Brian_
yup mines had about 2 inches of play since i bought her last year
Old Jun 23, 2012 | 06:13 PM
Craven23's Avatar
Craven23
So, the ticking I hear at about 15-22 moh is a possible steering shaft?
Old Jun 23, 2012 | 06:14 PM
Craven23's Avatar
Craven23
Sorry, mph
Old Jun 24, 2012 | 08:17 AM
priceman14's Avatar
priceman14
The ticking noise I refer to happens when I rock the wheel from side to side in the area of play - I don't really hear it much during normal driving.
