help wiring source
Old Jun 24, 2012 | 09:29 PM
dak_rider's Avatar
dak_rider
Default help wiring source
i need help looking for a wire diagram and layout
for a 1998 3.9L dakota from ecu/pcm to fuse box and firewall
and 2004 dakota 3.7L ecu/pcm wire diagram to firewall
almost finish my swap just the wire now
thank you...
Old Jun 28, 2012 | 06:32 AM
dak_rider's Avatar
dak_rider
any link or site to suggest
for wiring look out
diagram
pcm pinout
wiring
Old Jun 28, 2012 | 05:30 PM
00DakDan's Avatar
00DakDan
Section Moderator
Alldataidy.com will have the wiring diagrams. It is subscription based.
You're in for a lot of work trying to use the 3.7 pcm. The rest of the truck is not compatible. Dodge changed the computer bus in 2001 from CCD - 2 wire, to a PCI - 1 wire system. Most things, your instrument cluster, ABS, etc, are going to have problems communicating.
Old Jun 29, 2012 | 06:54 AM
dak_rider's Avatar
dak_rider
no i get the 3.9 pcm
all the wire but i want to check the wire color and there use
im trying to join them together to the 2004 body almost done
just wire and the front wheel left and gas line
