4.7 seafoam knock
Old Jun 24, 2012 | 11:08 PM
gassmann66's Avatar
gassmann66
Default 4.7 seafoam knock
so i read alot about it and decided to buy some seafoam to try it out, followed directions goven here in the forum 1/3 gas, 1/3 crankcase 1/3 vacuum lijne on the brake booster. got the tiniest puff of smoke after i started it up after waiting 10-15 minutes and truthfully never noticed a difference except the very faint knok that has been there if you got up in the wheel wells while the truck was on has now turned into a very noticeable knock that can be heard while just being around the truck. i know the 4.7 has always had either a lifter knock or an manifold knock (when cold) but this was even after a good 25-30 minute drive at full temp, so im gonna rule out the manifold (let me know if this could still be it) but my big question is could the seafoam be blamed for the louder knock?
Old Jun 25, 2012 | 12:12 AM
98DAKAZ's Avatar
98DAKAZ
Thumbs down I dont like seafoam
I don’t like seafoam you are forcing your engine to become flooded and almost die and usually start to knock badly and that is bad for any engine knocking
Old Jun 25, 2012 | 11:31 AM
Brian_'s Avatar
Brian_
seafoam is great for cleaning out the carbon deposits in the tb. im unsure about the knock, but i had stayed away from dumping it in the oil because of messing up the viscosity and making oil thinner. id do a oil change if i were you.
Old Jun 25, 2012 | 11:48 AM
gassmann66's Avatar
gassmann66
gonna have to, this whole 4.7 knock and its whole other list of problems is starting to get to me. love my truck but its finally starting to get to me!
Old Jun 26, 2012 | 06:32 PM
04 Quadcab's Avatar
04 Quadcab
For some reason, people seem to think there's magic in a can, and Seafoam gets a lot of attention on car forums. I looked up the MSDS, and I don't want it in my crankcase, I'll guarantee you; not much of a lubricant. As for cleaning out carbon, good 'ol H2O works great if you know how to use it. It can be dangerous if you don't, because you can hydrolock an engine and damage a piston or rod. I used to clean out carbon by gradually pouring water in the carb until the motor stumbled, shutting it off at that point, then letting it sit for awhile before restarting. But it does take a little technique. Best to just give the beast a hard highway run locked out of OD to get the rpm's up.
Old Jun 26, 2012 | 07:48 PM
bpark8824's Avatar
bpark8824
I used Seafoam last fall when my truck was running like junk. It was cutting out and bogging down, ran Seafoam through the crank, intake, and gas line, and within 50 miles it was running like new. I'm guess it was a clogged injector or something, but the Seafoam cured it.
