1999 balljoints
Old Jun 28, 2012 | 02:55 PM
bbeebee's Avatar
bbeebee
Default 1999 balljoints
FWIW, the Haynes manual is almost useless. So I watched a video and it showed a snap ring for the lower one. However, mine has no snap ring. It is a press fit with a flare, or flange, in the top. I peened the edges up and was able to hammer it out then.
Old Jun 28, 2012 | 09:38 PM
bbeebee's Avatar
bbeebee
Default update:installation drivers side done
FWIW, I don't have a ball joint press kit. To install the lower, I raised the truck off the jack stand using a piece of tubing, axis vertical, on a jack. The tubing I used is the almost the same diameter as the flat on the lower part of the body of the ball joint assembly. In effect, I used the weight of the truck to create the same direction of force a press would. When I then hit the lower A arm with a 4 lb mallet the impact slowly drove the ball joint into the A arm. Worked for me.
Old Jun 28, 2012 | 09:42 PM
ahsnowlover's Avatar
ahsnowlover
the factory ball joints have the flair on them, if the video showed removing a snap ring then they were replacing a aftermarket one.
