key broke off
Old Jul 1, 2012 | 06:32 PM
kenzspen's Avatar
kenzspen
Default key broke off
all dodge guys, i have a 2002 dakota with key broken off in ign, tried using other half and rocking wheel no luck. any tricks would be appreciated.
Old Jul 1, 2012 | 07:04 PM
01DodgeDurago's Avatar
01DodgeDurago
Default just an idea
Well I've never had that problem but thought if you could put a little super glue on the end of a small stick or other half of key and then stick it in for a couple min till glue sets up and try pulling it out??
Old Jul 2, 2012 | 12:12 AM
moe7404's Avatar
moe7404
paper clip, straighten, small 90 bend. just a guess
Old Jul 2, 2012 | 12:30 PM
dodgeramguy85's Avatar
dodgeramguy85
The thing about super glue is you run a risk of gluing the key in. You can call a lock smith and ask them if they are able to pull a broken key out. If not you are gonna have to replace the ignition switch.
Old Jul 2, 2012 | 04:15 PM
sxrsil3nt's Avatar
sxrsil3nt
Not sure about the ignition, but I just pulled a key out of a friends door on his civic - looked like someone tried to break in.
I know it's not the best idea but I drilled a hole on one side of the key and grabbed pliers and a pair of tweezers and eventually wiggled it out.
