PO441 03 Dakoda V6
Old Jul 4, 2012 | 11:40 AM
scurtaz's Avatar
scurtaz
Default PO441 03 Dakoda V6
Hello
I have been getting this code and can not figure it out, the only thing I have not done is replace the hoses (I just cut off the cracked parts and put them back on) and the O2 sensor. I am waiting on the O2 sensor it should be here tomorrow. It has also loss power and it just has a hard time getting going on the highway.
Any help would be appreciated
Scott
Old Jul 22, 2012 | 11:59 PM
bostondodge's Avatar
bostondodge
Cool
check the filler neck and hoses, and also the purge solenoid... i had the same issue. I replaced the filler neck and the check engine went off. I did a lot of research on that code and there is a bunch of things that could be going on... check out the charcoal canister, hoses, filler neck, and solenoid canister..
Best of luck!
Old Aug 22, 2012 | 10:10 PM
markk96's Avatar
markk96
Not sure if you fixed this or not, but replacing the NLVD pump near the rear canister solved my problem.
Old Oct 3, 2012 | 07:39 PM
Billb1970's Avatar
Billb1970
I also had a P0441 code as well. The NLVD pump was found to be not working so after the change all is well
