What Did I Break This Time?
Old Jul 8, 2012 | 04:52 PM
sxrsil3nt's Avatar
sxrsil3nt
Default What Did I Break This Time?
Hey guys,
I took the dak mudding at a buddy's cottage this weekend, had a damn good time and snapped a few pics if anyone's interested.
Anyway, drove home today and the truck feels fine but my girlfriend pointed out the driver side is sagging about an inch lower than the passenger. I jumped up and down on the bumper to see if it was just stiff but its still sagging. Are there common problems related to sag with these trucks? I can't see anything broken - maybe just worn out.
I only hit really hard once but it's not squeeking or making any wierd noises.
Old Jul 8, 2012 | 06:24 PM
EricBing's Avatar
EricBing
tires straight?? ball joints known to break upon landings.. mine broke and got drove into rim (PO)
Old Jul 8, 2012 | 06:28 PM
dirtbiker's Avatar
dirtbiker
Blown shock? Another thing (may sound dumb, but it's often overlooked) is to check to be sure the tire has enough air.
Old Jul 8, 2012 | 07:28 PM
mmguy18's Avatar
mmguy18
Check for a bad ball joint. Check torsion bar.Said you check and it was stiff. How stiff? Is shock working?
Old Jul 8, 2012 | 09:56 PM
jondakotaguy's Avatar
jondakotaguy
Get on flat surface and take measuring tape and check the actual measurements fender to ground as strait as possible. As much pressure it is possible for the pressure pulling down to spin out.. in that case a simple solution is to but another nut on the back side of the factory "thing" that the adjustment bolt is screwing into.. a second nut would not allow the bolt to back out under pressure.
And it's possible because it happend to a Jeep Liberty Rack and Pinnion; there was so much force it caused the worm thread inside to spin out causing the wheel to point out about 6 inches and nothing inside was physically broke.
Old Jul 8, 2012 | 10:16 PM
sxrsil3nt's Avatar
sxrsil3nt
Ill check it out tomorrow and let you guys know... I hope its not the balljoints cause I just had them replaced in November.
Old Jul 10, 2012 | 10:29 PM
RYCOMA79's Avatar
RYCOMA79
I had a strut piston shoot up and then sideways and jam suspension wouldn't move big pot hole check the shocks
Old Jul 11, 2012 | 12:20 PM
sxrsil3nt's Avatar
sxrsil3nt
I think my shocks are just going bad and sticking, checked the truck this morning and it's no longer leaning. Thought for sure I broke something
