brakes issue
Ok this past week i changed my driver side caliper cause it blew out. now accouple days later i am getting this weird pressure thing going on in my brake peddle. for instance everytime i hit the brakes they work normal then all of the sudden they get soft and then i get a large surge of back pressure pushing my foot back up again and they get soft again. does anyone have any idea what might be causeing this? Also i been hearing a sound coming from the back of my truck that sounds like 2 peices of metal rubbing on them selfs which i think might be the rear shoes so i have to check them tomorrow.
Sounds like air in the system or?
Did you replace the flex lines? Sounds like you may have a bad flex line thats pinching down on you.
You may have sucked air in the master if you let it get to low I would bleed all the lines to be sure.
Sounds like back brakes may need work
ok well i guess i know what i am doing tomorrow lifting the whole truck and removing all the tires and bleed the system from back to front. as for the flex lines when i put on the new caliper they didnt look bend or pinched but i will check them all when i remove all the tires tomorrow.
check the back brakes they may be a nasty mess I would not be surprised if black Dot 3 comes out of them lucky new cylinders are cheap $15 a piece
Trending Topics
well i will find out tomorrow lol. hmmm now that u mention it a peice of rusted pipe might have made its way to the back brakes cause sometime last year i had to change my steal line to the rear drums cause it exploded when i was driving down the highway one day how i made it home i have no clue..
well i checked all the lines and they are all fine. But when i went to look at the drums i found something not so good. Apparently 2 springs broke and the 2 internal cable clips broke and were grinding against the inside of the drum. so i changed all the springs on both sides of the truck and the shoes but only changed the drum on the passenger side. now it brakes a hell of alot better
