sway bar wear
Old Jul 15, 2012 | 02:06 PM
rbrenner's Avatar
rbrenner
Default sway bar wear
I have a 2003 dakota that needs some suspension work. If you hit a bump it is unstable. When I replaced the swaybar bushings last year I noticed excessive wear under the bushing. The metal was much thinner. The rear swaybar seems flimsy rusty and weak. Does anyone make upgraded / thicker swaybars?
Old Jul 15, 2012 | 02:51 PM
mmguy18's Avatar
mmguy18
Check around. I do not of anyone off hand. Try Summit Racing or one of the 4x4 off road stores. May look into the setup on a Dodge Ram see if is beefier and would fit.
Old Jul 15, 2012 | 07:59 PM
thunder98110's Avatar
thunder98110
hellwig makes a thicker sway bar. and moog has great solid endlinks.
