Check Engine Evap Troubles
Old Jul 20, 2012 | 07:45 PM
bostondodge's Avatar
bostondodge
Unhappy Check Engine Evap Troubles
Check engine light went on, got the code for evap... The filler neck was so rotted my ringer went through it while changing it out.. I figured that was the problem but after I cleared it I went about 160 miles then it turned back on.. Before i smoke it out anything else I should check out? Lose or cracked hoses?
The weird thing is i was due for inspection... after i replaced the filler neck and cleared, i drove the truck around 160 miles and the light didnt come on... i went and passed inspection and about 4 hours later is when the light came back on.
Old Jul 20, 2012 | 08:17 PM
Gears954's Avatar
Gears954
I think I have the same problem might be a Evap Charcoal can
Old Jul 20, 2012 | 09:25 PM
NullPointer's Avatar
NullPointer
Check canister under truck, think its inside the frame rail about at drivers door. I had split in lines coming off of it that was causing my evap code. Clipped the bad end off and slipped fresh hose one and back in business, no more code.
Old Jul 20, 2012 | 09:33 PM
chris1996's Avatar
chris1996
check the fuel pump mine used to has a escape there dont know how to call the piece but where the fuel pump joints with the regulator (dont know how to call that piece the one that regulates the pressure) and sealed where used to be a seal whit silicon glue
Old Jul 20, 2012 | 11:05 PM
bostondodge
Thanks for the reply's, ill check those out see if thats that problem.. Update coming soon .
