Anyone have CB's?
Old Jul 25, 2012 | 11:27 AM
Jonnymoon5's Avatar
Jonnymoon5
Originally Posted by Brian_
i would have thought duals increase the range?
suppose i should have done a bit more research
I believe its something like greater than 6 or 8 feet apart then it increases the range (i think)
Old Jul 25, 2012 | 12:01 PM
magnethead's Avatar
magnethead
Seeing as antenna theory is what I'm finishing up a research paper about, let me bring in some information from Andrew K. Dart, Operations Engineer at KDFW Fox 4 Dallas. http://www.akdart.com/
In regards to the "Cedar Hill Antenna Farm"'s close placement of towers,
Originally Posted by AK Dart
The towers are far enough apart to prevent disruption in the stations' coverage patterns. There is little or no interference or intermodulation between digital television stations because the signals are tightly filtered and anything outside their 6-MHz channels is 100 or 110 dB down. That's what makes it possible now to have adjacent TV channels coming from the same antenna farm, whereas in the analog days the only adjacent channels were 4 and 5 (because there is a gap between the two), 6 and 7 (big gap), and 13 and 14 (huge gap).
In regards to co-planar mounted antennas (referred to as candelabra systems),
The advantage of the candelabra is that several TV stations can share a large tower and have the same height above ground. It also helps make the radiation pattern more omnidirectional, because it's better to have another antenna support 75 feet away than to mount the antenna on the side of the tower. Especially at UHF.
Of course, many AM radio stations use several towers in close proximity, intentionally interacting with each other to produce an antenna pattern that conforms to the areas they want to cover, and more importantly, protecting the other stations on the same frequency that have been on the air longer. A few very old stations like WBAP are non-directional day and night and don't have to protect anybody. One interesting case in Dallas is KRLD, which protects a station in Hartford, Connecticut at night. Another oddball is 1190, which has separate day and night transmitter sites.
More information:
http://www.firestik.com/Tech_Docs/SNGL-or-Dual.htm
http://cbradiomagazine.com/May%20200...everything.htm
Old Jul 25, 2012 | 04:25 PM
dirtbiker's Avatar
dirtbiker
I run a Midland 5001z coupled to a k30 mag mount antenna. I get about 5 miles.
Be sure you get an swr meter and tune the antenna.
Old Jan 13, 2013 | 03:46 PM
Grumpa8637's Avatar
Grumpa8637
I'm using a Cobra 75WXST compact remote mount matched with a Larson NMO series antenna. Power and antenna connection inside my center console.
Old Jan 16, 2013 | 04:45 PM
Old_School's Avatar
Old_School
Not a Dakota but, same idea....
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
Old Jan 18, 2013 | 12:44 PM
DakCC4x4's Avatar
DakCC4x4
I have a small Cobra and it is wedged between the driver seat and the center console. My mic is mounted on the side of the cup holder and i run a full stainless whip.
Old Jan 21, 2013 | 11:43 AM
daveh1219's Avatar
daveh1219
I have a small Cobra mounted next to my gear shifter. I ran into the same issue with my Dakota because I have a manual as well and couldn't really find a good place to mount it. After some thought, on the side of the the gear shift was best for me. Its worked out pretty well for me. It is a pain trying to put the mic back on at night but its not bad at all, get used to it. I've always used dual antenna whips and haven't had any issue with signal.
Old Jan 21, 2013 | 03:13 PM
mmguy18's Avatar
mmguy18
I have a Cobra 25 and 4 ft fire stix. Found a company made a bracket for the Dakota that goes on fender.
