Rear end help!!
Old Aug 8, 2012 | 10:17 PM
  #21
Tom A's Avatar
Tom A
Section Moderator
Here's a decent setup guide.
Obviously, not all of this will apply to the job you're doing, but it still gives you a good idea what you'll need to do.
Old Aug 8, 2012 | 10:34 PM
  #22
Tom A's Avatar
Tom A
Section Moderator
Here's one place to get the tool.
Unfortunately, there's really not another right way to check the backlash. It's easy to do with the dial indicator, though. That link I posted should show you how. Basically, you want to put the plunger on the edge of the ring gear (on a tangent), then hold the pinion while you rotate the ring gear to check the play between the gears (backlash), which should be around .008".
  #23
hillbillyphilly18's Avatar
hillbillyphilly18
man i really appreciate the help. on my carrier when i go to take it out. if i just loosen one of the adjusters and leave the other right where it was, cant i just tighten the one i moved back up and shouldnt that put the carrier back into place? and what kinda of tool is it im looking for for the adjust *****/screws?
Old Aug 8, 2012 | 10:38 PM
  #24
Tom A's Avatar
Tom A
Section Moderator
To be honest, I've never tried it that way. You might be able to leave the right nut in place and just remove the left. I don't know if you'll be able to get the carrier out or not.
Old Aug 8, 2012 | 10:41 PM
  #25
hillbillyphilly18
hey i geuss its worth a try. i read that someone on another forum had done that. not sure if it was a success or not. is there a chart of some kind with all torque specs? mainly the pinion nut, and adjusters?
Old Aug 8, 2012 | 10:46 PM
  #26
Tom A's Avatar
Tom A
Section Moderator
Torque chart
Old Aug 8, 2012 | 10:51 PM
  #27
hillbillyphilly18
man you are a saint. im gonna add u as a friend. lol i thank ya. and ill keep ya updated. it probly wont be till saturday or sunday before i get to work on it but ill post the results. thanks again.
Old Aug 8, 2012 | 10:58 PM
  #28
Tom A's Avatar
Tom A
Section Moderator
No problem, dude. I'm happy to help. Definitely let me know how it goes.
Old Aug 8, 2012 | 11:40 PM
  #29
moe7404's Avatar
moe7404
to check the back lash, you need to use a travel indicator, NOT a test indicator. allso you can use a cigarette paper, and newspaper paper. if you get it set so that cigarette paper can be rolled between the teeth with out getting cut, but the newspaper paper is cut off. will be good.
Old Aug 8, 2012 | 11:50 PM
  #30
Tom A's Avatar
Tom A
Section Moderator
Well, there you go. There IS a hillbilly way, lol. I learn something new every day.
