which throttle body to use
Old Aug 25, 2005 | 08:11 PM
drjgarage's Avatar
drjgarage
Default which throttle body to use
I have a 2003 3.9 Dak. What throttle body would someone recommend using if I was to change it? And what would it accomplish?[8|
Old Aug 28, 2005 | 04:14 PM
SinCity R/T's Avatar
SinCity R/T
Default RE: which throttle body to use
Installing an OEM 50mm (w/48mm "torque ring") throttle body from a Dakota R/T is probably as big as you want to go. You may gain a couple of horsepower from the swap, the bigger advantage will be helping flow more air to support other parts (ie: headers, heads/cam, etc)
Old Aug 28, 2005 | 06:17 PM
D Bone's Avatar
D Bone
I use The Fastman 46mm TB on my '99 V6. It bolts right on with no cable swap like you have to do when you use the V8 TB swap.
www.thefastman.com
Darryl
Old Aug 29, 2005 | 05:04 AM
TexasNative's Avatar
TexasNative
let us know which one u do because Im looking at doin the same thing. Im hoping it really compliments all my other mods!!!
