rev to 3000 rpm uphill
Old Aug 10, 2012 | 08:34 PM
Jon_2's Avatar
Jon_2
Default rev to 3000 rpm uphill
This question is for a durango with the 5.9 i figure same thing anyway truck drives fine everywhere but up hill revs to 3000 rpm but with no power to the ground but drives fine everywhere else
Old Aug 10, 2012 | 09:35 PM
Tom A's Avatar
Tom A
Section Moderator
Stick or automatic?
Old Aug 11, 2012 | 01:00 AM
Hahns5.2's Avatar
Hahns5.2
Durangos were only available with an auto.
Old Aug 11, 2012 | 03:31 AM
Tom A's Avatar
Tom A
Section Moderator
Oops, I was thinking Dakota. Not clutch slippage, then. I would put a fuel pressure gauge on it and see if it's losing pressure under load.
Old Aug 11, 2012 | 09:22 AM
00DakDan's Avatar
00DakDan
Section Moderator
46RE? Possible slipping overdrive clutch.
Old Aug 11, 2012 | 09:59 AM
Jon_2's Avatar
Jon_2
What do you mean by 46re?
Old Aug 11, 2012 | 10:07 AM
00DakDan's Avatar
00DakDan
Section Moderator
What model transmission is it?
There is no information other than 5.9 Durango.
Since you've posted in this forum I'll assume it's a 46RE.
Old Aug 11, 2012 | 10:34 AM
Jon_2's Avatar
Jon_2
Where would i find out which trans it is?
Old Aug 11, 2012 | 10:59 AM
Jon_2's Avatar
Jon_2
The durango is an slt with the 5.9 unless they used a different trans in the RT i would assume its the same wich im pretty sure they used the 46RE in the RT's but its not mine its my gf's uncle and he is getting advice from a bunch of military tech which are telling him some crazy stuff unless your a tech into cars as a pass time you never touch normal cars but still think there top mech lol
Old Aug 11, 2012 | 12:04 PM
00DakDan's Avatar
00DakDan
Section Moderator
It should be the 46RE behind a 5.9.
It really sounds like a slipping clutch.
