Crankshaft Positioning Sensor
Old Aug 15, 2012 | 12:42 AM
gdjohnnson's Avatar
gdjohnnson
Default Crankshaft Positioning Sensor
Can anyone tell me where to find the CPS on a 2000 Dakota with a 4.7 magnum engine? Thanks in advance to whoever knows this!
Old Aug 15, 2012 | 05:02 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Your looking for a replacement sensor at a store?
Or the location on the engine?
I will move this to the 2nd generation Dakota sub-forum.
Old Aug 16, 2012 | 11:47 AM
gdjohnnson's Avatar
gdjohnnson
the location on the engine,I found what seems to be it on the pass side rear by the block heater,..I put the new sensor in and it still doesn't run,..I was driving it,..shut it off for 4 hrs,and it hasn't started since,just cranks like there is no spark.
Old Aug 16, 2012 | 11:50 AM
gdjohnnson's Avatar
gdjohnnson
Default 2000 Dead Dakota
was driving it,shut it off,,4 hrs later went to start it,and it will not fire at all,..just cranks but no start. I can hear the fuel pump cycle when the key is turned on,..new CPS did no good. any ideas anyone???
Old Aug 16, 2012 | 06:43 PM
00DakDan's Avatar
00DakDan
Section Moderator
Any codes?
Turn the key on, don't start it. Then off, on again, off, then leave it on. It will display any codes in the odometer window.
Old Oct 11, 2012 | 10:28 PM
gdjohnnson's Avatar
gdjohnnson
the problem was the Camshaft sensor,changed that and it runs again!!! Dodge's technician found and fixed it!!
Old Oct 18, 2012 | 02:17 AM
gdjohnnson's Avatar
gdjohnnson
Can anybody tell me where I can get a suspention lift for my 2000 Dakota Sport 4x4? all I can find is the 2" leveling keys for the front!! I want a 4" suspention lift kit!
