transmission problem
Old Aug 22, 2012 | 04:28 PM
00DakDan's Avatar
00DakDan
Section Moderator
You are much better off with a dealer filters. Especially in light of what's going on.
Watch what you're reading for units of measure.
The rear (9 1/4) takes about 4.9 pints or 2.32 liters. An 8 1/4 takes 4.7 pints or 2.22 liters (about 2.5 quarts).
The front holds 3.5 pints or 1.66 liters (1.75 quarts).
Old Aug 22, 2012 | 06:52 PM
vaskydive's Avatar
vaskydive
Thanks for the info on the filter and gear oil...I'll be at dealership in morning to get the filters...regarding the gear oil you're correct on the amounts....but I was only able to get 2qts in rear and one in front (took the rear apart... but suctioned out the front) what a pain the front is....Once I get the new transmission filters replaced I'll re check the diffs...Thanks again for the info...Lee
Old Aug 25, 2012 | 07:07 AM
vaskydive's Avatar
vaskydive
Well I finished replacing both filters and and now the CEL has come on and I still am unable to engage the transmission! There was a slight leak but tightening the pan bolts resolved that on Friday night. Is there a way to check codes without a computer? Had a Dodge Neon before and I was able to turn the key a couple of times and based on the number of times the engine light flashed that was the code.... I can not remember the sequence though....other wise I need to tow the vehicle to the shop on Monday...$$$....thinking this was a mistake and should have brought the vehicle to dealer like the wife said...LOL...
Old Aug 25, 2012 | 08:15 AM
EricBing's Avatar
EricBing
where is this cooler return filter located??internally??
Old Aug 25, 2012 | 09:54 AM
00DakDan's Avatar
00DakDan
Section Moderator
You can pull some of the codes:
Starting with the key off, turn the key to on (not start), then off, on, off, on, off, leave key on.
Give it a second or so each time you turn the key on. Any codes will show in the odometer window.
Old Aug 26, 2012 | 09:49 AM
vaskydive's Avatar
vaskydive
Engine Malfunction light remains on.....blinks 12 times then remains on
Old Aug 26, 2012 | 09:55 AM
vaskydive's Avatar
vaskydive
forgot to mention...NO CODES appear in odometer reading...waited 3-5 minutes
Old Aug 26, 2012 | 10:48 AM
00DakDan's Avatar
00DakDan
Section Moderator
That's odd.
Try it again, give it a few seconds between turning the key either way so you see the lights come on on the dash.
Otherwise, you'll need to get it scanned.
Old Aug 26, 2012 | 11:03 AM
vaskydive's Avatar
vaskydive
Tried it again...it could be 11-1 (there was 11 flashes at a consistent rate than a very brief pause / flash
Old Aug 26, 2012 | 11:41 AM
RYCOMA79's Avatar
RYCOMA79
obd 1 code says 12 flashes battery disconected in last 50 key on cycles 11 flashes means no camshaft signal or timing belt has slipped so nothing to do with transmission. I had a problem like this with an intrepid turned out trans cooler had leaked and drew in coolant destroyed torque converter and all the clutches
