hazards work, turn signals don't
Old Aug 19, 2012 | 07:33 PM
tmkf_patryk's Avatar
tmkf_patryk
Default hazards work, turn signals don't
Alright, so I have a 2000 dakota here and I am stuck.
I got out the wiring diagrams and connections and everything.
The multifunction switch works (the turn signal arm). Tested it all according to shop manual (continuity checks for neutral, left, right, and hazard).
When I unplug it and run some wires into it, I can get the left and right both to work independently.
Checking the fuses, they seem good, and the flasher I take it works as the hazards (and without the switch) it works.
I am damn lost
Old Aug 19, 2012 | 07:52 PM
tmkf_patryk
reading over, looks like it may actually be the flasher?
Old Aug 20, 2012 | 12:52 AM
mmguy18's Avatar
mmguy18
I believe the flasher could be partially bad and work flasher and not turn signal.
Old Aug 22, 2012 | 11:28 PM
tmkf_patryk
it was the flasher. Replaced and everything is fine
