2000 Power Window Prob
Old Aug 21, 2012 | 03:33 PM
Jamielew's Avatar
Jamielew
Default 2000 Power Window Prob
2000 Dodge Dakota SLT 5.9L - FDS window will not go up. The three other windows all go up and down fine using the FDS control panel switches. What should I replace? All three other windows only work with the FDS control. It's like window lock is on. Any suggestions are appreciated.
Old Aug 21, 2012 | 03:48 PM
00DakDan's Avatar
00DakDan
Section Moderator
All the window wiring goes through the "FDS" door switches. It's a common failure point.
Old Aug 21, 2012 | 04:02 PM
Jamielew's Avatar
Jamielew
Thanks. So now stupid question but what is the solution?
Old Aug 21, 2012 | 04:28 PM
00DakDan's Avatar
00DakDan
Section Moderator
Replace the switch assembly.
Old Aug 21, 2012 | 04:29 PM
01SilverCC's Avatar
01SilverCC
You may need to replace the driver's door window switch assembly, it is a common problem. I have read here that some guys have had good results from removing the switch from the door panel and spraying the connector plug with a good electrical contact cleaner. You may also be able to spray inside the switch itself to help clean it. I don't have a lot of info on it, I have manual windows so I never done it myself. If cleaning the switch does not work, my own opinion on it is to buy a new switch from the Dodge dealer. I have little faith in electrical parts from the junk yard..
Jimmy
Old Aug 21, 2012 | 04:45 PM
ALLDATAdiyINFO's Avatar
ALLDATAdiyINFO
Former Vendor
Alldatadiy.com has information on sensors and switches. Good luck with your resolution!!
