Transfer case clicking
Old Aug 28, 2012 | 05:19 PM
mmguy18's Avatar
mmguy18
Question Transfer case clicking
Got a issue with the transfer case clicking when truck is in gear. Does not matter if it is in reverse or drive. Any thoughts? Has electronic shifter for transfer case
Old Aug 28, 2012 | 08:20 PM
EricBing's Avatar
EricBing
get a partner put your hand on shift motor(black plastic) on bottom of xfer case, can you feel anyrhing?? Oh does 4 wheel drive work and engage properly??
Old Aug 28, 2012 | 08:48 PM
00DakDan's Avatar
00DakDan
Section Moderator
Is this the vehicle in your sig or something else? A 2000 is not electronic.
Stretched chain maybe?
Old Aug 28, 2012 | 09:17 PM
mmguy18's Avatar
mmguy18
Sorry different truck.Has button shifter 2wd,4hi,4lo. Says it is in 2wd and the 4wd did worked. With someone in the truck put it in gear and can hear it clicking put hand on transfer case you can feel it.
Old Aug 28, 2012 | 09:27 PM
00DakDan's Avatar
00DakDan
Section Moderator
Could be the chain. May also be a bad bearing.
Old Aug 28, 2012 | 10:05 PM
ahsnowlover's Avatar
ahsnowlover
I had that same problem and ended up replacing the transfer case, found out that the shift forks were messed up and didn't want to hold it in 4wd. As long as it was in 2 wheel it wouldn't make any noises.
