lots of play in the steering
Old Aug 31, 2012 | 10:27 PM
Vladek's Avatar
Vladek
Default lots of play in the steering
i have just rebuilt the front end on my 97 dak. even after installing a new gear box. i still have alot play in the steering. i am wondering if there is something that i am missing, like a adjustment screw or something. my chilton manual doesn't say anything about it. any help or info would be nice.
Old Aug 31, 2012 | 10:35 PM
mmguy18's Avatar
mmguy18
What about steering shaft?
Old Sep 1, 2012 | 12:51 AM
Vladek's Avatar
Vladek
that is all good. no play in u-joints on the steering shaft. plus i have changed both upper and lower ball joints, tie rod ends, hub bearings, pitman arm and idler arm. the only play that i have found is in the gear box. that is new too. i didn't see any bolts for adjustment. seeing that i'm just a shade tree mechanic, didn't know if there is something that i missed.
Old Sep 1, 2012 | 11:14 AM
98DAKAZ's Avatar
98DAKAZ
Default Inside
Inside I think they are called Tie Rod End were the tierod connects to the Rack and Pinion
Old Sep 1, 2012 | 11:29 AM
Vladek's Avatar
Vladek
i don't have rack and pinion. wish that i did tho. otherwise i would just switch it out with the 01 parts durango. but after looking at things. it would require a lot of skill with cut and welding to the frame.
Old Sep 1, 2012 | 11:31 AM
Vladek's Avatar
Vladek
sorry. forgot the mention that my tie rod ends mount on to the centerlink. so i don't have inner tie rods.
Old Sep 1, 2012 | 11:57 AM
98DAKAZ's Avatar
98DAKAZ
Lightbulb I suggest grab a good friend
I suggest grab a good friend have him constantly turning the steering wheel back and forth as you look at every moving part of the steering system start at the steering shaft and work your way down to each side look for any slop at all.
Best you do the inspecting not him it’s your Dakota he will not be so inclined to be so watchful.
Also look at the suspension system for slop
One more thing look for things moving that should not be moving
Old Sep 3, 2012 | 08:49 AM
Vladek's Avatar
Vladek
looked it over, all the play seems to come from the gear box.. surely the is a way to adjust it? everything else is tight.
Old Sep 3, 2012 | 12:03 PM
98DAKAZ's Avatar
98DAKAZ
You may just need a new Box it may be missing some teeth or the worm gear bearings are shot especially if your play is bad like you say.
Old Sep 3, 2012 | 02:58 PM
mmguy18's Avatar
mmguy18
There should be a adjustment. Try downloading the manual on the header of this page or try Autozone. com under repair help. They should have a copy of the Haynes manual you can look at.I have rack in mine but any other truck I have adjusted with a gear box has had a set screw an a nut to hold it in place.
