transmission swap
Old Sep 1, 2012 | 03:08 PM
00dak4.7's Avatar
00dak4.7
Question transmission swap
hey, new to this forum but i need a little help with a transmission swap on a 00 slt quad cab 4.7l auto. im in the middle of it right now, i just need to know where all the trans to engine mounts are, and what you guys suggest for the best way to remove it.
Old Sep 1, 2012 | 03:39 PM
moe7404's Avatar
moe7404
from engine to trans is a ring of bolts. you did keep track of where the bolts go, didnt you? THE most important thing is the two allinement pins, i think are on the the bolt circle as the bolts. the pins are press fit in the trans i think. the pins should be 1/2 dia. if the pins are not in it will tear up the flex plate and torque converter. please pardon the copy and past. add this to your chrysler trans. an external fluid filter
1. go to auto-zone. get 2210, its called a power steering filter, but it is for transs to. it is for 3/8 tubing. by (magna-fine) be sure to use high pressure hose.
2. for other sizes wix 58964 5/16 tube size
NEW SUBJECT: .distributor moisture fix. Some chrysler distributor cap that has an air vent, needs to have the vent plugged. Best to use JB-weld. But there might be some brands that run air through as part of the system, dont seal them
Old Sep 2, 2012 | 07:51 PM
00dak4.7's Avatar
00dak4.7
any info on an easy way to get the top bolts from trans to motor out. these bolts are a pain, im workin on this slowly cause i got a'lot of other s**t goin on right meow. but any info would help
Old Sep 3, 2012 | 08:44 PM
moe7404's Avatar
moe7404
i have seen two ways to get the top bolt. 1. get a swivel socket, on a very long extension. 2. from the top use a box end wrench, use the box end. its kind of slow, but works.
