Loud Squeak
Old Sep 6, 2012 | 08:31 AM
dbrown2679's Avatar
dbrown2679
Default Loud Squeak
When I first bought my truck, there would be a loud squeak from the front end whenever I hit a bump, turned my wheels, get in my truck, etc. So I replaced my shocks, which helped a little bit. After getting under my truck, in the area I call the a-frame, there is a little black boot that separates when the truck is jacked up, and sits and rest when it is on its own weight. I can take photos later, but these boots are ripped to shreds, and I believe that is what is causing my squeak. Does anyone know what the boot is called? From memory, I believe it sits below my shock or there area there of. I have been looking for diagrams of that area but haven't been successful. Thank you.
Old Sep 6, 2012 | 09:18 AM
durandall05's Avatar
durandall05
That sounds like you are describing the bump stops. If your truck is resting on the stops then you need to crank on your torsion bars to lift that front end up!
Also:
Old Sep 6, 2012 | 09:26 AM
dbrown2679's Avatar
dbrown2679
Edited due to adding an image.
Old Sep 6, 2012 | 09:47 AM
dbrown2679's Avatar
dbrown2679
Edited
Last edited by dbrown2679; Sep 9, 2012 at 09:18 AM. Reason: Edited due to actual images.
Old Sep 6, 2012 | 09:10 PM
Vladek's Avatar
Vladek
bump stops, your can get them for $30 to $40 at parts store or $5 to $15 off ebay.
Old Sep 7, 2012 | 01:08 AM
durandall05
So that is not a pic of your truck?
Old Sep 9, 2012 | 09:17 AM
dbrown2679's Avatar
dbrown2679
These are the pictures off my truck. As I was looking, I believe my bump stops are ok, at least it is what sits above these. But thanks.
IMG_0797.jpgPASSENGER SIDE
DRIVER SIDE
Old Sep 10, 2012 | 12:12 PM
durandall05
dude your stops are destroyed! Since you said is squeaks when going over bumps or turning I think that cranking on your torsion bars would help. In theory it would raise up the suspension giving you more up-travel before hitting the stops.
Old Sep 10, 2012 | 01:35 PM
98DAKAZ's Avatar
98DAKAZ
Talking
durandall05... ha ha oh boy I second that those are destroyed TOAST man ha ha wow.
Should look like this
new from rockauto $15 each
Old Sep 11, 2012 | 09:13 AM
dbrown2679's Avatar
dbrown2679
Lol thanks fellas.
