Shift kit
Old Sep 18, 2012 | 09:34 PM
AIC Peters's Avatar
AIC Peters
Question Shift kit
Would anyone know of a good shift kit to improve torque on a 2004 dakota 4X4 and a 3.7
Old Sep 18, 2012 | 09:59 PM
moe7404's Avatar
moe7404
get a hold of these guys.
A & Reds Transmission
3737 W. 29th South
Wichita, KS 67217
1-800-835-1007
1-316-942-8947 i have known these guys since the late 60s. 90% of all trans shops use A REDS
Old Sep 19, 2012 | 12:22 AM
mmguy18's Avatar
mmguy18
had good luck with B&M. Haven't use them on a Dakota though.
Old Sep 19, 2012 | 07:15 AM
DakinUK's Avatar
DakinUK
I'm pretty sure that your truck has the RFE545 gearbox. Its FULLY electronically controlled so a regular shift-kit (stronger springs etc) won't work as the pressure sensors will compensate for any increase in pressure the new springs generate.
What you need is this
http://www.sonnax.com/product-lines/...ion/parts/1960
It made a big difference on mine, after a conventional kit failed to do anything. It just plugs in, so no dropping the pan to fit.
Old Sep 19, 2012 | 09:23 PM
AIC Peters's Avatar
AIC Peters
that is the V8 trans and i have a V6 trans (a 42RE i think)
Old Sep 19, 2012 | 10:07 PM
magnethead's Avatar
magnethead
I believe all three *.7 motors use the 545 but I could be wrong. Only the magnums use the 4*RE i believe.
