Top ball joint rivets removal made easy
Old Sep 19, 2012 | 08:41 PM
98DAKAZ's Avatar
98DAKAZ
Lightbulb Top ball joint rivets removal made easy
Here is some info that may come in handy
I just drilled out my top Ball joint rivets with only my 14.4 volt battery Dewalt and it worked out fine didn’t need the powerful corded drill like last time.
I also tried only one drill size ¼ not three sizes up till it was drilled out and this worked way better than the old three drill sizes slowly drilling the rivet out way.
I think this worked better all-around it was easy, only hard part was the hammering out the rivet one was easy the other was not so easy.
I also did this without taking anything off except my tire then drilled them out one at a time and put a bolt in as a replacement as I’m not removing the Ball joint just yet just getting ready to do them but now all I need to do is un-bolt them in a day or two when I’m ready to replace my ball joints and bushings on my passenger side.
Oh I used some grade 8 nuts and bolts as a temp replacement for the rivets
Always trying something different
Old Sep 19, 2012 | 09:51 PM
98DAKAZ's Avatar
98DAKAZ
Talking Tools I used
Results
Old Sep 20, 2012 | 12:35 PM
00daksport25's Avatar
00daksport25
I remember when i did mine it was hell getting them damn things out.
Posted from Dodgeforum.com App for Android
Old Sep 20, 2012 | 05:59 PM
crateampsrock's Avatar
crateampsrock
I work for midas, I do dakotas and the full size rams with rivets all the time. I used a snapon air hammer with a chizel bit to knock off both caps, then a pointed bit to hammer down the shaft of the rivet... takes about 2 minutes per rivet...just have to be careful not to bugger up the control arms too bad... If you get a stubborn one just apply some heat...
Old Sep 20, 2012 | 06:21 PM
98DAKAZ's Avatar
98DAKAZ
Well yea
Some great power air tools and a shop lift will take care of anything ASAP
But Im talking Home DIY job I think it took me 20 minutes total.
Old Sep 20, 2012 | 06:25 PM
crateampsrock
outside the lift.... everything i listed is available to anyone here...
Old Sep 20, 2012 | 06:26 PM
98DAKAZ's Avatar
98DAKAZ
True but most dont have them
Old Sep 20, 2012 | 08:11 PM
magnethead's Avatar
magnethead
we have a 120psi 40 gallon compressor, but an air chisel is out of our reach. But that's what a die-grinder with carbide blade is for. We still have air tools from 15+ years ago. Our impact is 25 years old, socket retainer broke off, but it still works. Just have to make sure the socket doesn't go flying.
Old Sep 20, 2012 | 09:10 PM
Tom A's Avatar
Tom A
Section Moderator
Same way I do them. If you pay attention to the angle of the chisel, it doesn't mess up the control arm at all.
Old Sep 20, 2012 | 09:15 PM
pasinby's Avatar
pasinby
Same here , just added a box of Band Aids and a six pack.
