drive shaft part id
Old Sep 25, 2012 | 06:49 AM
baldrudy's Avatar
baldrudy
Question drive shaft part id
I have a 2000 dakota extended cab 4x4 auto trans. Where the rear drive shaft ujoint clip goes in the holder it is broken . it looks like some adaptor piece with 4 bolts that hold it to the rear end. Does anybody know what this piece is called and a part number for it? Also is there any interchageable parts and what years they fit? thanks rudy
Old Sep 25, 2012 | 01:46 PM
New 2 Dodge's Avatar
New 2 Dodge
Do you mean the pinion Flange?
File Type: jpg
Old Sep 25, 2012 | 02:15 PM
baldrudy's Avatar
baldrudy
it is the part on the driveshaft that is on the ground next to the socket and extension as shown in the picture
Old Sep 25, 2012 | 09:43 PM
New 2 Dodge
that would be the Ujoint flange
Old Sep 26, 2012 | 12:07 AM
master tech's Avatar
master tech
Site Moderator & Tech
The driveshaft flange part number is 5015556AA, the u-joints are both the same number 5014733AB and if you need the bolts, number 6506497AA. These are all mopar part number. Thats if you have a one piece driveshaft. If you have a two piece driveshaft, then you need to replace the whole drive line.
