how bad is the job of replacing a water pump on a 318?
Old Sep 25, 2012 | 08:06 AM
Cody Smith's Avatar
Cody Smith
New Member
Default how bad is the job of replacing a water pump on a 318?
ive got a 99 dakota slt 318 and the water pump went out and i dont have the money to take it to a shop so i know its a tight place to work where the pump is but any body every replaced one on this model dakota and can tell me what im getting into
Old Sep 25, 2012 | 11:32 AM
Crazy4x4RT's Avatar
Crazy4x4RT
I will move this to the 2nd generation Dakota sub-forum.
Old Sep 26, 2012 | 12:16 AM
master tech's Avatar
master tech
Site Moderator & Tech
Its not that hard to replace. But a little trick, after all the bolts have been removed use a hammer and hit the water pump from the bottom of the pump. Not the top. That because if you hit the pump at the top of the pump, you will most likely break the seal around the timing cover. If you hit it the pump from the bottom, you will be fine. Because you have 4 bolts on the bottom.
Old Sep 27, 2012 | 12:31 PM
UWAdventurer's Avatar
UWAdventurer
The bolts are differents lengths, so I made a diagram and labelled each bolt with a piece of tape. All in all it wasn't that bad, the hardest thing to remove for me was the Fan/clutch assembly.
