Cruise Control Troubleshooting
Old Oct 1, 2012 | 09:26 PM
  #21
00DakDan's Avatar
00DakDan
Section Moderator
It actually connects to all of the switches in some way.
Scroll down on the schematic. Where do the other ends go? You can test the switches/wiring from there.
Old Oct 1, 2012 | 09:34 PM
  #22
00DakDan's Avatar
00DakDan
Section Moderator
Actually, you don't have to test the wiring. Since you get the "cruise" light you know that wiring is intact. You can still have a bad "set" switch however but the wiring is good.
If the wiring was bad you wouldn't be able to turn the system on.
Have you tried sealing that hole in the servo? Maybe it will still work.
Old Oct 1, 2012 | 09:44 PM
  #23
Custer's Avatar
Custer
Thank you...I've about had it for today. The good news is this may help others.
Thanks again...You rock!
My next step. Bet you can't wait to say "I told you so"! I called the wrecking yard but it was to late tonight but I'll try in the morning.
Stay tuned!
Old Oct 2, 2012 | 01:46 AM
  #24
olsarge's Avatar
olsarge
Originally Posted by Custer
Thanks but you must not have noticed I mentioned the brake switch multiple times in my posts.
It's not urgent that I have it. I hate being stumped and just would like to solve it.
Can anyone answer this regarding the brake lamp switch?
"Try jumping terminals 1 and 4 together and then see if you have power at the cruise control servo."
1-F32 14PK/DB FUSED B(+)
4-V32 20YL/RD SPEED CONTROL SUPPLY
I get power to the servo when jumping so I know the wiring works. I bought a new switch and it didn't solve my issue.
Other than the brake light switch there is a cruise control switch at the brake pedal.
Old Oct 2, 2012 | 09:52 AM
  #25
00DakDan's Avatar
00DakDan
Section Moderator
It's all in one, not separate.
Old Oct 2, 2012 | 12:27 PM
  #26
Custer's Avatar
Custer
Man wins.
00DakDan Prevails!
I removed the servo last night and that hole definitely was the issue as I bench tested it for suction. I melted some spare plastic to the housing, performed some plastic welding then sealed it with silicon. This morning I took the truck out for another test drive and BOOM the CC works. I spent a lot of time troubleshooting and 00DakDan was terrific. I also learned more about how the CC system works which will help me help others...No regrets.
The problem.
The fix.
Old Oct 2, 2012 | 02:13 PM
  #27
00DakDan's Avatar
00DakDan
Section Moderator
Thanks for the update. Glad we got it.
