99 Dakota Sport 4x4 (i got some questions)
Hey,
So i have had this 99 dakota sport 4x4 now for a about a month or two. I bought this truck one for the winters here in Indiana and two so i had something i could haul with.
after getting the truck for 2400 with 130000 miles (not a bad deal)
when looking over the truck more i noticed that it had an old body lift on it almost 4" im guessing and to me that large of a body lift looks stupid cause you can see your frame and everything.
so my question, what type of suspension lifts are out there to raise the actual frame up (I know about the torsion keys and all) but whats a good brand
and is there anyway i can find out how the truck came out of the factory stock so i can put the original body spacer size back on.
some other details of the truck is, it's the 318 5.2L, its a dark gloss purple with typical chrysler clear coat problems :/ (want that fixed too), and axle back exhaust (no my choice)
And if you have any advice on what to do to the truck would be helpful cause i do plan on driving it 120 miles one way to see my parents once a month in northern indiana
Thanks
Thanks
![Smile](https://dodgeforum.com/forum/images/smilies/smile.gif)
Cheapest way would just be to make your own gapguards if it's the gap between your bed and frame that you mean.
If you mean the frame hanging out the bottom of the truck then yeah there isn't much you can do. Not many suspension lifts for dakotas other than the one dodgeramguy recommended, and keep in mind they only made those for 97-99.
Heres how it sat stock with stock 31's
Heres how it sat with just a torsion bar crank and on stock 31's(about 1 1/2in-2in higher than stock)
^^^ Yours would sit a little higher than this with keys and blocks^^^^(tires would be the same)
Then 32's no change in height.
Personally scrap the ifs and do a solid axle swap. You would have just as much money into it. Plus you have a stronger axle and you can go tons of cheap routes for lifting it. I wouldnt even waste my time on a ifs lift for the dak. I would do a 3in body lift and torsion keys and blocks and be able to stuff 35's under it.
Trending Topics
