Rattling noise when A/C on and foot on brake while in gear
Old Oct 9, 2012 | 12:29 PM
Canuckman's Avatar
Canuckman
Default Rattling noise when A/C on and foot on brake while in gear
This is sort of an extension on another thread I made.
I have a 2000 Dodge Dakota 3.9 with AC.
There is a rattling noise from the belt tensioner pulley ( when I look at it is rattling against itself) when I put the A/C on or heat on and put foot on brake while in gear or while accelerating after stop. Noise disappears when in Neutral or when A/C off / heat off.
I have yet to take the belt off, though I notice that if I pour water on the belt the noise goes away for a bit before returning.
Further, though not sure it has to do with anything; the temps are starting to get cold here and in the morning the belt squeals a bit before warming up.
I'm asking for help since I need to order parts in but I'm broke and would rather only order the park I need (say belt, or new tensioner...) than order a bunch to troubleshoot it. Any ideas? Thanks a ton in advance
Should also note, the sound isn't always continuous. If I sit there listening to it, it'll be subtle, than you can hear the fan from the AC kick on and the noise will start as the RPM's jump a little.
Old Oct 9, 2012 | 12:47 PM
New 2 Dodge's Avatar
New 2 Dodge
sounds like the clutch on your AC compressor. Mine was bad and yes it makes a bad noise. You have to replace the entire compressor, they don't sell individual parts. If you have a refridgerant guy, you can get off a little cheaper. Compressors are about $200.00 or so but easy to change once the refridgerant is out
Old Oct 9, 2012 | 12:55 PM
Canuckman's Avatar
Canuckman
Would that explain the rattle when the heat is on as well?
Old Oct 9, 2012 | 01:02 PM
00DakDan's Avatar
00DakDan
Section Moderator
I tend to think you have a bad tensioner. When it's weak, it slips, binds, slips, binds, causing the chatter.
The a/c compressor is just putting a big load on it more likely increasing how often it slips.
The compressor can run in defrost mode too.
Replace both the belt and the tensioner.
