Airbag Light
Old Oct 12, 2012 | 12:18 AM
N1CK's Avatar
N1CK
Default Airbag Light
My airbag light flickers on and off periodically. I think I have a lose connection. Can anyone tell me how i can go about fixing this?
Truck: 2001 Dodge Dakota 4.7
Old Oct 12, 2012 | 10:03 AM
00DakDan's Avatar
00DakDan
Section Moderator
It can be a lot of different things from a bad connection to the clockspring.
Does it seem to do it more when you turn the wheel in a certain position?
Check all connections, carefully.
I know it's not DIY but if it isn't an obvious issue you're probably better off taking it to a dealer and getting it scanned. If the light is on it should throw a code. A regular code reader won't detect it, you need a DRB.
