2003 Dakota engine problem
Old Oct 23, 2012 | 08:21 PM
4x4forlife's Avatar
4x4forlife
Default 2003 Dakota engine problem
Hi, I have a 2003 Dakota 3.9l v6 4x4. Every time I start it up it will quit in under 10 seconds, even if I give it gas it will still quit. In the short time it runs it sounds fine. I have not done anything to it because I just got it but I was wondering if anyone had any idea what is wrong with it, thanks.
Old Oct 24, 2012 | 06:54 AM
Crazy4x4RT's Avatar
Crazy4x4RT
I will move this to the 2nd generation Dakota sub-forum.
Old Oct 24, 2012 | 10:01 AM
cummingetit's Avatar
cummingetit
Test your fuel pressure to see if it holds steady or bleeds off. Only thing i can think of right off.
Posted from Dodgeforum.com App for Android
Old Nov 13, 2012 | 07:47 PM
metaliox's Avatar
metaliox
Sounds like O2 sensor. My 96 3.9 had a similar problem where it would start - run fine for about 10 seconds then start to stall like it was starving for ruel or air. Was a cheap fix. Dont let this hinder you. The 3.9 is a fantasticly reliable engine. I drove that 96 for just over 250000 miles. Parts were cheap and it took some of the worst punishment ive ever seen.
